Crossed wires
SCAdventure
Lake Murray, SC
Not a problem with my Grady but with my deck boat. It has analog gauges that all work fine however when I put my running lights on the voltometer pins down below 10 volts and the the fuel gauge show up to full. This does not happen when I only put the mooring light on.
Any thought where to start?
thanks
The fuel gauge pegging to full is a dead giveaway. You have a bad ground. Check the ground terminations on your running lights.
Mike,
Tighten your negative batt cable, check all the grounds on your gauges and ground bus under the helm. Just as in a car, a ground issue can be hard to track down. But a ground problem is the source of 99.5% of 12VDC issues...
