If someone does YOUR homework for you, and provides you with a direct placement that worked for their boat, yet it doesn't fit your boat (Grady could change suppliers over the years), will you be snippy with them, as well?Obviously.
Figured someone here already went through this and knew a direct replacement.
It's NOT obvious that you knew what to do to find new cupholders - I was merely giving you the info needed to go out and get whatever cupholder works best for you. I wasn't being condescending or anything like that - just trying to show how easy it is to figure this out. Heck, walk into just about any marine store and they might have something in stock that would work.
That's what I meant. I offered the information needed to find a replaceable cupholder, yet was met with a sarcastic response. Based on the information you provided in the first post, it was NOT obvious that you knew to do that - or that measuring was important since there are different sizes of cupholders available (and possibly different sizes used over the years and with different models. But, that's fine.Easy there, the internet is supposed to make our lives easier.....
Not entirely true. The cupholders in my boat are smaller - "just" big enough for a 12oz can. I've seen plenty of other boats with smaller cupholders, as well. There are also variances in larger cupholders from one brand to another - I know this from trying to replace cupholders for customers over the years. While the 3-3/4" hole seems to be one of the more common sizes, it's by no means "standard". They can be different by a good 1/4" - which, depending on who/what cut the original hole means it may not fit. El Mar has got his measurements, though, that's the important part.They are pretty much standard at 3-3/4 ID hole and 4-1/4 OD of flange.
It all dates back to the first 7-11 Big Gulp....then fast food joints supersized drinks and then 20 oz plastic bottles...
lip on replacements covers the ring. makes it a tight fit. also a nicer finish around the fiberglass hole.I guess it depends on the lip on your replacement. You want it to fit tight to the fiberglass surface, with out a gap.
