deck drain Marlin300
ttles714
NJ
I believe the port side aft cockpit deck drain has either ruptured or disconnected from the outlet fitting which is just above the aft port waterline. When I flush it, no water exits the hull side fitting and I hear water running inside the hull somewhere . So How do I access these fittings and hoses to repair or even see whats going on .
put out the live well and you should be able to reach them.
I should have been more specific>>> boat is a 2007 Marlin300... The older models has the live well at the port aft transom .. my live well is Mid ship behind the port companion seat.. . I have a removable "bucket" where you indicate the live well would be .... under it is the battery compartment .. Maybe removing all the batteries and the "shelf" holding them ???? IDK ???? I figured I would ask first >>> yes the boat is out of the water sitting on a trailer ...
