- Aug 28, 2007
Looking at a 28 footer. What year did they make these and what kind of engine/s are in it? Anyone have experience with one? How much fuel does it hold?
gradyfish22 said:I do not even think there were 50 made of this model, 50 would be the max number I wouls suspect. It was a volvo engine with a duoprop outdrive. I believe the engine was a single 265hp Volvo KAD44. It topped out around 30mph and cruised around 20-22mph. The single engine and low hp for that model made it a sluggish boat and therefore not popular, also moving a lot of weight in a boat that size in a boat designed for a totally different propolsion system did not make it a good candidate for a diesel I/O for ride quality. Performance was good when uit comes to efficiency, but speeds stunk. I've heard from many they do not ride great since the hull was designed to ride totally differently then how it performs with the diesel. Persoanally if I wanted a boat with diesels in the 28 ft range I'd buy a Carolina Classic, it might burn some more fuel, but the ride will be 100x better, they are tanks and have more usable cockpit space with no big engine box. Only advantage the Grady has is the aft berth, but unless you really plan to sleep the boat with a few people, then this space ends up being storage or not used anyways. I would highly advice a sea trial if your still interested in this model, I've heard too many say they were unpleased with how it handled, not sure what they had privious though and what they honestly compared it to or expected, for your needs it might suit you fine, especially depending on what you might be coming from. I've been on a few I/O Grady's over the years, and not 1 drove anything like their outboard version, a few actually ran better since they had more weight and stayed in the water more, others ran like junk. Have not personally been on a 274 other then at a show years back when it was brand new. The idea is great and the efficiency is hard to beat, plus Volvo makes a great diesel engine that is very reliable.
