Dual Battery Access suggestions on 257 Fisherman?
Gradyful Crew
Northshore, MA
Fisherman 257
My dual batteries are located in my center console, behind a larger panel that is screwed on. There is an access hatch built into panel to allow access to the battery terminals, but full batteries can’t be removed through access hatch. At the top of the screwed on panel the fusion radio head unit is mounted, which restricts full removal of larger panel. Has anyone made a modification to the larger panel to allow for bottom half removal to access batteries easier? Any other suggestions to improve full battery access?
Just unplug cables on Fusion and note which ones so you can plug back in when you reinstall panel. Replaced a battery the other week and went smoothly.
