Electronics box ram
grady33
Ocean Pines, MD
For the electronics box in 2006 330 noticed that sometimes my ram doesn’t want to go down. Not sure if switch or ram. Goes up always fine but now and then when I try and lower, it doesn’t work. I jiggle box and switch and raise a little and then it works. Anyone have any problems?
If the ram uses two wires and works OK in one direction but needs some wiggling for the other direction, most likely the switch is bad
My 2007 330 has exhibited the same symptoms in the past. The switch is a momentary one and spraying it out with contact cleaner seem to alleviate the problem. When I bought the boat the ram had recently been replaced. I’m thinking that maybe the switch was a problem all along.
