Enclosures for T Top
If your looking for a 3 sides enclosure, if the model is still current or within I believe 6 years, Grady still has them or can get them, if not they need to be made custom. Grady's are never cheap, and custom are better if you get a good canvas maker to do it right, you can have air vents put on the top to unzip, no water on you but fresh air, you can have the sides be able to be designed to lay flush against the console, but can be unsnapped from the console, folded out and then attached to the gunwales to keep you and your crew dry while underway if it's windy. I'd find a good canvas maker near you, let us know where your lcoated and maybe someone local will have recommendations for you. It is good to use guys who are recommended instead of taking a stab in the dark.
Had a local canvas guy make all new enclosure, interior cushion covers and some of the cockpit cushion covers for a fraction of the cost that Grady would charge on my 2000 Marlin (for things Grady could supply, savings were in the 50% range)
Support your local canvas guy[/list][/code][/quote]
