- Oct 6, 2010
- East Falmouth
- Express 265
One of my trim rams is leaking an I'll be replacing the seal in the spring since the boat is high and dry. I plan to make a tool to make it easier to remove the cap, similar to the Yamaha tool but with a handle, sort of like the one on ebay. It's a good winter project for the upcoming snowy days!
My boat is shrink wrapped so I can't get to the trim cylinder so I was wondering if one of the Southern readers- the ones I'm envious of because you don't need to pull your boat- could measure the outside diameter of the cylinder and the ram itself. Does't need to be precise, I'm primarily interested in ram diameter so that I cut the right size hole in the center of the tool. My motors are 2004 but I don't think it matters as long as it's an F225.
Thanks in advance.
Thanks in advance.
