After hauling my Marlin this year, I found I have two gashes that are the length and with of a pencil on the bottom of the hull. It took off the gelcoat down the fibers in the mat.
It may have cut a few strands loose but did not cut into the mat.
What would be the best way to fill this in? Do you have to use Gelcoat since it will be barrier coat and painted back over? I want to make the best possible repair and keep water out of the fiberglass mat.
Thanks.
Thanks.
