- Mar 17, 2019
- Age
- 45
- Wilmington, NC
- Express 330
The Fischer Panda 4200 4kw on my 2006 330 has been trouble since I got it a few months back. Long and short is that it starts up, runs for 15-20 minutes, the oil pressure light starts flickering, it runs for another 15-20 minutes, and then it shuts itself down. If you wait 20-30 minutes, you can restart it and go through the same process. It is a rebuilt unit that the old owner put on, and it has 45 hours.
I had a Fischer Panda certified mechanic out there today, and he found that the oil pressure at start-up is 20, and then it instantly drops to 10. Those numbers are very low, he tells me. When it shut itself down, he tested the pressure again while trying to restart it, and it was zero. When we could restart it 20 minutes later, he put the oil pressure gauge on, and he could see the pressure steadily falling while it ran. He talked on the phone to the FP service guy at the factory in Fort Lauderdale, and there was no clear answer. He is going to research a little more before recommending a plan, but he thinks the next step is likely going to be removing the unit from the boat to tear into it and get at some of the seals and the oil pump.
The mechanic seems like he is shooting me straight and knows what he is talking about, but I just wanted to throw it out to the Grady-owning masses to see:
1. Has anyone had this issue before? and if so, was there any fix that could be down without dragging the unit out of the boat? and/or
2. Has anyone replaced their FP with something else? I have not been hearing great things about these, and if I am going through the trouble of removing it from the boat anyway, it may be a good time to replace it with something better.
All thoughts are appreciated.
Thanks.
Thanks.
