Forward Bilge Pump
Time to replace the Attwood V1250 under the mid berth. Stopped working. Looks like the pump is the root cause. The new Tsunami model replaces the older V line. Went with the 1200 gph (same as was there). Wanted to go with the Rule but the current draw on the pump was more. Anyone have experience with the Tsunami line?
Reactions: Ozz043
The pump arrived today. The new Tsunami pumps are surprisingly quite small and look to be an easy install.
Installed very easily. The original mounted with 3 screws. Could only use one of the holes as the diameter of the pump is smaller than the original.
An important job done .....next one on the go probably
