Fuel Gauge
JJRJR
Hey guys,
1992 Gulfstream 232. As you know, there's one gauge on the dash and if you want to know how much fuel is in each, you flip a switch and it tells you. I think the main tank is reading correctly, but the front one is way off. Tank is full, but reading about 1/4.
Found a loose connection at the gauge that we fixed, but still reading wrong. Any thoughts? What would be the likely culprit here?
Thanks,
John
I have the same boat in a 96. I just pulled the sender out of the tank and the float is lodged up inside its housing. I ordered an other WEMA sender 14" and plan on replacing it tomorrow when Amazon arrives.
Keep in mind the screws need to be eased out and may be a little tough. Also, the holes on a sender are not symmetrical. It only fits one way so it will take a little patience lining the new ones up. Be sure to replace gasket too.
Also keep in mind that this is NOT a job to do with any kind of battery or plug in power tool. Either use a hand screwdriver or an air powered one.
One spark and your day will be ruined....
