Fuel in bilge after a fill-up (2001 Marlin)
Comfortably Numb
Southwest Florida
(Original post deleted)
Problem solved.
The fuel water separator that used to supply the generator that I removed had corroded through, allowing fuel to drip out the bottom.
UPDATE:
I looked around some more with a flashlight, and found the fuel filter and the fuel filter housing that goes to the generator heavily corroded. It's too dark to remove and inspect tonight, but I'm about 90% sure that's where the fuel came from.
There is no fuel valve shut off to that fuel filter, so I plan on removing it, and installing a fuel valve tomorrow.
