Fuel tank sending unit size 208 Adventure
magonzo
Does anyone have experience replacing the sending unit on a 208? If so, what size or part number did you use?
Thanks...
To confirm, I'd pull the old one out of your tank and measure its length before buying anything.
But, this is the one I installed... 10.5 inch length.
Item# Item Name
SSS/SSL SSS/SSL Fuel or Water Level Sensors (4 - 60 in.) (Length - 10.5 in.)
http://www.wemausa.com/sensors/level-FuelWater.shtml
The tank on my 208 uses the SAE 5 hole pattern, so I bought the top one listed on the webpage.
Thanks for the information. That is a great starting point. My boat is a 1994, so I suspect it will be a very similar set up.
