Fuse Holder Question
jrgrady
Ok, quick question here, if I am installing new fuse bus bars behind the dash, do I still need to install the little round fuse holders on the dashboard. Doing a dash-redo and want to keep it clean. Obviously, every switch will still have it's own fuse with everything labeled, but the fuse will be hidden, but still accessible if need be.
Personally I would get rid of every in line fuse holder that I could and use a fuse panel type holder. Also I would use an electrical grease on all connections and fuses.
You can put fuse panel elsewhere than switch panel, if you have the room.
