Gas tank
Abarnes
I live in Virginia and just got a 25 sailfish I am going to restore. The floor has already been removed and the fuel tanks were also removed. Does anyone have the tank dimensions and know where the best place is to get them done? If anyone has pictures that would be extremely helpful as well.
Best bet is to go to the Grady White website and send an inquiry with your model and year. They usually get back in 1-2 business days and will provide original specs as well as current equivalent part numbers if available.
You can also try searching this forum using Google; works way better than the built in search.
site:www.greatgrady.com “search term”
Atlantic Coastal welding in New Jersey does good work. That may have the specs on hand. They will ship but note that shipping can add a decent expense to the tank cost
On their website that have info on tank installation. If you are going to install your tank yourself, I recommend you read their article. It has some good info that can avoid issues later
Reactions: Abarnes
