Gelcoat help
Gotchagrady
Got tangled up in some low water recently and a have a couple of good scratches in gelcoat on boat of my hull. I have a 236 fisherman that is Newport blue color. Does anyone know if Grady males or recommends the color to use for the gelcoat repair? Spectrum suggests celestial blue, but can’t tell if it is a match..
you can buy the gelcoat patch material from your Grady dealer. It may be the same product as the Spectrum color but probably will be more expensive
Fiberglass Coatings will color match gelcoat if you can't find it.
Gel coat isn't that easy to use. If color match and finish quality is that important to you why not get it professional done? Either the dealer or a glass guy they recommend.
