When we go cruising to Desolation Sound, we often anchor out and make use of our tender, which is an Ocean Air aluminum RIB with 8 hp Yamaha 4 stroke. This tender (97 pounds) and motor (90 pounds) is ideal for towing in calm water but we wanted a pot puller which would double as a davit to mount the dinghy on the back deck of the Marlin. After a lot of searching we found a pot puller robust enough to handle the tender.
Quality Products Northwest in Port Townsend, Washington manufactures a variety of pullers and their Alaska Super Sport My-T-Hauler, rated at 250 lbs seemed ideal. After a few discussions with QPN, we agreed on options (e.g. reversing capability) and several modifications to make the puller a little taller and stronger.
Tender: Ocean Air aluminum RIB, model -OA250, length: 8-2”, weight: 97 lbs
http://oceanairtec.com/Models.html
Motor: Yamaha F8B 8HP 4 stroke, weight: 87 lbs
http://www.yamaha-motor.ca/products/det ... atId=82#ts`
Hauler: Quality Products Northwest, My-T-Hauler, model: PL-MTH-2100-90CU
http://www.qualityproductsnw.com/produc ... 2100-90cu/
Quality Products Northwest takes the time to produces a very high quality unit. More details may be seen at:
https://www.flickr.com/photos/john_c_bo ... 777526320/
