Gulstream hull cored or no?
Denko
SE Michigan
So another project I have between now and spring launch is installing a thru-hull transducer. Can anyone tell me if the bottom of the hull of my '96 Gulfstream is cored or not? From the transducer instructions it looks like the process for a cored hull is more involved, still doable but probably not a one-day job.
Thinking spring,
Dennis
The hull bottom is not cored. Only the hull sides above the waterline are cored for stiffness and to lessen weight.
Sounds good, thanks! Should be no problem now... :roll:
