Hard top tubing diameter
SCW
Cape Cod
Looking to add a couple clamp on rocket launchers to my boats hard top. Does anyone know the diameter of the tubing on the hard top? 2011 Freedom 275 with factory hard top. Thanks in advance
So the tops are made with pipe which is measured inside. When the measure 1" pipe it will be about 1.25" outside, 1.25" pipe is about 1 5/8" outside and 1.5" pipe is just over 1 7/8" outside. If you go online you can find exact outside measurements but this should be able to get you close.
Reactions: Ky Grady
Thank you! Love your work!
I just added some clamp on rod holders to my 226. It has an after market hardtop. It has 2 sizes of pipe on it . I mounted to the smaller tube which had an outside diameter of 1.315. That is one of the common sizes. I bought new Lee's rod holders on ebay for $100 for 4. The second picture shows the larger size pipe.
