- Mar 10, 2012
200 hp 2003 2 stroke ox 66 fuel injection idles at 1200.motor should idle at 600-700.any help appreciated
Good question.Winged Pig said:Did it just start doing this after running fine?
There is a connector that can be disconnected to force the motor into a special mode. Basically, all the logic of the ECU are overridden. This mode can be used when the EUC fails at sea. I have to check and see if the connector cable is greenWinged Pig said:The reason I asked is I once pulled a cowl off my OX66 225 to check things out and when I put it back on it disconnected a green wire at the rear of the motor. Motor started up just fine but would not idle down. After looking for the problem and re-connecting the wire (plug connection) everything returned to normal. Lesson learned for me.
Anyway, hope that helps.
BobP said:Do the OX66s run all 6 cylinders when idling, my HPDIs don't.
