- Oct 16, 2007
- Age
- 71
- Cape May, NJ
- Islander
You will get different gauge sizes depending on the voltage of the system. I believe you mentioned you were going to run three 12-volt batteries to make a 36-volt system. Using the circuit length and amperage you provided with a 36-volt system, the calculator comes up with 8 AWG wire (UL 1426 wire). I would recommend building a margin of safety into the system, so 6 AWG should be more than adequate, according to the calculator.According to that calculator, I can get away with #6 wire. I put in 30 ft length, 40 amp load and 3% max drop and it gives me #6. Am I doing that right? I haven't ordered the wire yet. I will order that crimper that Chris recommended and some red and black shrink tube.
Check the max wire size for the trolling motor connector. You may need to drill out the back to accommodate 6 awg wire. I would no go to 4 awg. Given it's a 40 amp circuit 6 arg and the length are adequate. If you do decide to go to 4 awg you should do a short 6awg pigtail into the connector. Use a reducing splice.
For my last project (replaced battery charger cable and 12-to-24 volt conversion for Lingren-Pittman dredge reels) we used Pacer Group for tools and materials. We bought a FTZ crimp tool from Amazon. If you are that concerned about voltage drop make sure you get the best crimp tool for the job. You want perfect crimps. Also make sure you used a tinned marine grade wire (not the untinned welder cable)
Pacer Group - Marine Wire, Battery Cable and Electrical Parts
A Top US manufacturer of marine wire, battery cable, and boat cable. Buy direct and SAVE. Shop 9,000+ products. 40 years Supplying OEMs quality electrical parts.www.pacergroup.net
Did you complete the installation?GW, you are right about the wire size. Earlier in this thread the discussion got into recommendations of #4 And even #2. I ordered some supplies including a Marinco Plug-in connector intended specifically for trolling motors. It indicates on the package that 6 gauge is the biggest wire it will accept. I thought WTF? It turns out that RHODAN company is only about 12 miles North of me, so I called the guys there and one of their techs said #6 is fine anywhere I place my battery in a 22 ft boat. The fact that this motor can handle up to a 15,000 pound boat and mine only weighs about 6,000lbs, he said the draw, for the most part will be fairly low. He told me to just feel of the circuit breaker and the plug-in connector for temp as I use it and get familiar with the system. He said to expect them to be warm but if it gets to where I can't hold my hand on either one then some change is in order.
I used #6 ANCOR tinned cable in a casing and after the member Finest Kind suggested I look at a single 36 volt Lithium battery for only about $120 more money, thats the route I went, using the same battery he recommended. I haven't got out to try it yet because I have some other irons in the fire but will soon.
Yes, I did finish it. I had put a resettable breaker with manual trip for a disconnect out of the weather in the cabinet with the battery but I found that with all the crap that gets put in there, it was unhandy to get to at the end of the day. I installed an on/off rotary switch in a handy spot to kill power to the system. It bothered me to only have that wireless remote for a kill switch in case something went amiss. I was able to angle the mount for the motor enough that the starboard bow seat is still usable and the motor head is still a couple inches inside the rub-rail. There is a cup-holder right where the head lands so I McGivered a hold down for the head that included a foam toilet ring for an RV and a bungee cord. I'm not sure the patent office is going to let me in the door with that one for sure.Did you complete the installation?
Thanks for taking my suggestion, I hope the Lossigy 36V 100 Amp LiFePo4 is working as well for you as it does for me.
