help replacing gauge panel
ray leonard
switching from omc to yamaha multi-gauges looking to get new panel so as not to have empty holes.whats commonly used for this application ?thanks for any help
Parthery
Atlanta, GA
Black acrylic, carbon fiber, or 1/4 inch black starboard. All will work well.
Fishshoreman
Fairless Hills, Pa / SEA ISLE CITY, NJ
If you decide to go with carbon fiber make sure it does not touch any aluminum. If the panel is currently screwed in I believe the rivnuts (if applicable) are made of aluminum. This will cause dissimilar metal corrosion. Use stainless steel hardware and if the rivnuts are aluminum I would change them to stainless. I changed mine to stainless on my switch panel.
