help troubleshooting, lost all power
tilewave
new jersey
hello, i was out in the ocean yesterday cruising at slow speeds for awhile searching for bait. i put the boat in neutral and my motors & electronics turned off like someone hit a switch. electronics bleeped a few seconds later. i switched over to both batteries ( not sure what else to do ) and i regained power. when back at dock, i switched back to batteries #1. and it started no problem any suggestions ?? thanks in advance...john
I'd check both batteries and your connections. Make sure they're clean and free of corrosion. I would also check your grounds to make sure they are good.
yes thats what my mechanic told me to do also, going on saturday to try to fix the problem needed a little direction thanks for the post
Sounds like another members same post recently.
Perhaps same professional mechanic is common factor? (Just kidding - I hope!)
