jskylar said:
My center lift ram was leaking so I purchased new unit from Andy at Simm's. I have the lift complete lift mechanism removed and the center rod the holds the ram to the unit on the bottom has a circlip that I removed, but I can't get the shaft out. It appears that it can only be removed from the side where the clip was, and the other end is a little smaller and has no clip. Does this need to be pressed out? Last project before I put back in the water to give everything a test.
Is the power trim and tilt mechanism removed from the motor or not? You say that it is but then you say you can't get the tilt piston pin (the one with the circlip) out. If the pin is not removed the ptt mechanism can't be removed.
The normal procedure would be to position the motor to the full up tilt position and use the tilt lock lever to hold it there. Then, remove the circlip that holds the pin in place. The pin will then slide out of the tilt piston. A hole is cast into the midsection so the pin can be removed. You might have to jockey with the trim switch to remove any load there may be on the tilt piston. The pin is not pressed into place. Once any load is removed it will come out with just a little bit of finger pressure.
Once the pin is removed, fully retract both the tilt piston and the trim pistons. Disconnect the electrical harness from the relay and pull it all out of the engine pan. Unbolt the bolts holding the assembly in place and the entire ptt mechanism will simply slide out from between the clamp brackets.
You can then proceed to remove the tilt piston cap.
