- Nov 30, 2016
Sunny days are on the way! Don’t get stuck out on the water without the proper shade to protect yourself from the damaging sun and harmful UV rays.
Carver’s USA Made Bimini tops are ranked at the top in the industry - featuring the best materials, components, and customer service. Why is Carver better than the competitor, you ask? Well, you can expect key features like: brass eye straps and adjuster buckles (most others are plastic), a double-walled main bow for added strength (competitor’s use a single bow), acrylic binding, a free matching storage boot, and no raw edges on the canvas or boot.
Selecting the correct size Bimini Top for your boat can be a headache and time-consuming, so we’ve taken the guess work out of the ordering process. You can simply choose your year, make, and model from our selector box to find the suggested size top which is guaranteed to fit your boat.
https://www.boatcoversdirect.com/products/bimini_tops/carver/
Already have a size top in mind that is sure to meet your needs? Easy enough – shop by dimensions and choose your desired length, width, and height from our selector box.
Not sure what size top you want and we don’t have your boat listed? We can help here too! Simply measure the width between the desired mounting locations to determine your mounting width. The height is best determined while standing in your boat, measuring from the mounting location in an imaginary vertical line, straight up to the point where you want the top to fall. Finally, decide whether you would like 6’ or 8’ of coverage from front to back.
https://www.boatcoversdirect.com/products/bimini_tops/by_dimensions/
You can choose from 4 varied materials, nylon or stainless steel fittings, and even add accessories like a brace kit or slide track.
Have questions or just want to speak with someone before placing your order? Simply pick up the phone and give us a call or shoot us an email. We’ll respond quickly to help you get your top ordered and on its way! We stock hundreds of Biminis in our facility that can ship same day!
When placing your order, be sure to mention the forum to receive an additional 10% discount off the online prices!
Shannon with Boat Covers Direct
1-866-626-8377
shannon@coversdirect.com
1-866-626-8377
