skimac420 said:
Couple of questions then. Where is the best place to get gelcoat, resin, etc...
You've got a few choices. For gelcoat you can get color matched stuff online from Spectrum Color or Minicraft, you can buy OEM Grady gelcoat from your local dealer or you can pick up standard white gelcoat and coloring agent from your local retailer. For a faded boat, your best bet is to go with that last option and color match it yourself.
Same thing for resin. There are many online suppliers and you can get it from local stores. I've seen polyester resin at auto parts shops and home stores. Never used that type of poly, never will. If you want "real" poly, look such places as U.S. Composites and FGCI. Same thing for vinylester. I think the same places even carry epoxy. Often times you can get sample kits, which contains small doses of resin, fillers, glass, etc for under $20.
I have personally used vinylester resin from U.S. Composites, epoxy from Raka and epoxy from West System (not West Marine...although it is sold there). At this point, I think my favorite is the vinylester. It wets out mat and cloth very easily.
skimac420 said:
How do I best match gelcoat color?
Buy straight white gelcoat and a tube of brown coloring agent. When you add the brown, you only need a TEENY TINY amount. Add it in super small doses until you get the color you want. Too much and you have to start over. If you think what you're adding won't make a difference, cut it in half and then cut it in half again.
Don't catalyze it until the color is right. As soon as you put the catalyst in, the clock starts ticking.
skimac420 said:
What type of resin would you use? What is best?
Best? It's all relative. They each have their benefits.
Poly is the cheapest, has the lowest strength secondary (mechanical) bond to existing structures and is the most prone to absorbing water.
Epoxy is the most expensive, has the strongest secondary bond and is pretty much impervious to water pentration.
Vinylester is right in the middle.
That being said, don't necessarily shy away from poly. That's what the hull was made with, so it's not necessarily bad. Lots of shops use it for repairs.
I've heard people say wood absorbs poly and vinyl better than epoxy.
One other thing I forgot to mention is that resin mixed with cabosil will often leave small pinholes once sanded. Sometimes you gelcoat will fill these, sometimes not. So you may have to "fair" the area before applying the gelcoat. This simply means filling the pinholes and low spots with a compound that sands easily. I've used Evercoat's Formula 27 filler as well as West System's 410 Microlight (mixed w/ epoxy) for this. Both work well, but from what I've heard there are other ones that are easier to use.
Is your head spinning yet???
