IN THE DARK
trimix
palm harbor florida
I have a 1999 268 GW Islander and would like to know where I COULD FIND NAV. LIGHTS for the deck to match original. port and starboard sides?
The ones I see on line are to small , My lights are approximately 3" in length and 2 1/8" wide. any suggestions or where to look on line?
thanks
Trimix
There's usually some type of brand/model on the interior/underside of the lights. What do you see there?
You could look through Perko's and Attwood's online parts catalog to see if you can match something up - and then find a retailer.
Does it NEED to be just as big? Meaning, all you really need to do (usually) is get something big enough to cover the old hole. Any screw holes not re-used/covered can be filled or even just run screws with finish washers into them. Or use a simple piece of 1/2" HDPE as a mounting plate. Just a thought!
Thank you Dennia
I have the running lights in my hand and nothing is written in or on them not even maid in Japan!lol
But I will look into attwood's parts catalog
It looks like the original was likely an Attwood 13-103 cockpit light, where a Google search didn't pull anything up with that model number, of which it would make me assume it's long since been discontinued or there's been a change of model number or two since then. They appear to still make something similar in a 3" diameter that I've attached below, of which they made a standard style of bulb for it as well as it looks like an LED option.
