How do you determine the proper Water separator sizing for a 1998 OX66 250 HP? Is it based on GPM of fuel flow, micron size? Trying to ensure I don't replace the element with one too restrictive. Thanks.
Patsy Mac said:How do you determine the proper Water separator sizing for a 1998 OX66 250 HP? Is it based on GPM of fuel flow, micron size? Trying to ensure I don't replace the element with one too restrictive. Thanks.
Dennis,DennisG01 said:Agree with everything above (10 micron) and will add... Sometimes it's best to not overthink things. You'll end up wasting lot's of time and energy researching and second guessing yourself. Think of it this way: Is your current filter working fine for you? Then replace it with the same one.
seasick said:Dennis,
I wish my brain could make things as simple as that!
DennisG01 said:Yes, there's more than one school of thought on the subject. "Generally" speaking, you start with a course filter and work your way down to the final filter. If you start with a fine filter, it can get plugged up much sooner than it should and could leave one stranded, although carrying a spare filter can solve the stranded part.
For what it's worth, my VST tank and VST filter has been absolutely spotless for the 3 seasons that I've had this boat - zero fuel issues (starting with a 10 mic, boat-mounted filter). The VST tank takes less than 30 minutes to remove - easy enough for once a year piece of mind. But simply draining the tank and checking fuel quality should suffice 99% of the time as anything starting to clog the VST filter will likely also be floating in the fuel.
seasick said:In ten years, I have never replaced the VST screen. I inspected it once and gave it a cleaning. I replace the 10 micron separator every season and the on board filter very 4 or 5 years. My experience with several Series II motors at my club is that VST issues often show up as dropping revs issues and not breakdowns. Most issues I have seen at the club relating to fuel have been water that got into the tank, usually through the fill cap. It is amazing how often I see Perko combo (fill and vent) caps that are missing the o-ring.I replace my o-rings every now and then.
I do not add stabilizers during the boating season but I do use Valve-tech fuel. Contrary to a lot of folks opinion, it does contain ethanol but it has some additives for marine applications.
This year it's time for a new on board fuel filter cartridge. It's been 5 seasonsOne thing I do try to avoid is fueling up early in the season when the fuel dock tanks has gas that has been sitting all winter.
It's not worth the risk of an explosion. There are ways to eliminate the explosive vapors but I am not going to encourage that approach.Tucker said:I'd like to see this inside of one of these. Is there a safe way of opening a used one?
