- Jan 23, 2022
- Age
- 74
- Freedom 335
All of you who have inverter systems do you have the boat on constant charging when not in use? Since I am dry stacked that would not be possible without some hassle with cables in shed.
How big an inverter have you installed to run 3 ACS, Cabin Helm and freezer.
Can you also use an electric Grill and Microwave? And how about charging the starter battery(ies).
Of course the duty cycles can vary wildly and in my case when not fishing much it is mainly creature comfort and cruising that counts.
I used to have gas inboards and Gas generator on a sedan bridge and gen used gas tanks but could not drain the tank as the pick up was at 1/4 tank level I believe. So if tank goes to 1/4 gen is starved.
THe diesel in current case is not bothering me but I could like a larger tank!!
H
H
