Inverter
93marlin28
Considering purchasing a 2007 33’ Express 330. Panda generator had failed and was removed. A Magnum Sine inverter/charger system was installed. Batteries were installed where generator used to live. Not sure if they are dedicated for the inverter or not. Inverter itself was installed on the starboard “wall” of the aft berth. I know very little about this system. Do the 2 Yamahas charge the batteries when on the hook and voltage starts to drop? Does the inverter give off a lot of heat? Does anybody have any experience with these? Any thoughts or advice would be appreciated. Thx
Too little info for us to help. There is no way of knowing without looking at it. What model inverter?, Watts? , 12v or 24 v?
Did they reconfigure the rest of the DC battery connections?
They "should" have the Yamahas charging them thru an Aux charging cable or thru an ACR.
