LED Inserts for Floodlights + anchorlight
Clockwork
ive got the stock deck lights on my 1990 overnighter. i would venture a guess that they suck alot of juice. i am looking if anyone knows of an LED conversion that i can install into the existing fixture. same for the anchor light. i have not seen any in my searches. thanks.
I changed my bow lights and all-around light completely, with units from Attwood. They almost perfectly match the OEM bow lights, and the 2nm LEDs are great.
Got tired of fighting corrosion in the lamp sockets.
If you're in SE FL Boatowners Warehouse has an array of inexpensive LED's for nav lights.
Switched out my dome lite and anchor/running combo.
Check them online, they probably ship.
Fishin' Rod said:
I replaced every light bulb on my boat last year with LED bulbs from the NAV lights to the courtesy lights. I like fishing at night and the LEDs draw a lot less current. Here is another website that has a replacement LED bulbs for every type of bulb you need.
http://www.superbrightleds.com/
How can you tell the leds from superbright are up to spec? I like having 2NM nav lights. Don't like paying $50 each for them. I believe the anchor/running light is about $120.
