LED Replacement Bulb for search light
djohnson52
Rhode Island
Anyone aware of an LED replacement bulb/kit for the Jabsco 60020 Series 135 SL? It is a sealed beam unit and I cannot find any replacement options besides the original halogen bulbs. Thanks.
Do some research on this to double check me, but I've read that an LED has a different light "disbursement" pattern (for lack of a better term). Because of that, the entire lens and reflector needs to be designed for an LED's pattern. In other words, if you simply put an LED bulb in there, you probably wouldn't get a good beam. With the inexpensiveness of that unit, and even if there was a whole lens/reflector/bulb kit available, it probably wouldn't be worth the money to do it. And, because of that, there probably isn't a kit available. But again, take this with a grain of salt and double check.
I looked in the past when I converted what I could to LED. Does not appear to be an LED equivalent.
