Live Well Pump on 23 Gulfstream
roblehnert
Cutchogue, NY
My livewell pump on my 1992 23 Gulfstream died, and I want to replace. First question - where is it? Second question - have any of you replaced it, and do you have any ideas for this?
Thanks,
Rob Lehnert
GW Livewell pump
My Gulfstream, albeit a couple years older, livewell pump is located under the passenger seat (take out drawers and bottom wood plate). You'll see it right there. Mine was a Johnson pump and pretty easy to replace.
Check
Forgot one thing-do a voltage check and see if its the pump or the wiring. As wires get older, corrosion builds up till its not delivering a full 12 volts at the pump. Easy to do-pull pump out and connect to a battery (note + and - terminals).
livewell pump
I also have a '92 Gulfstream in need of a livewell washdown pump.It is located portside,aft. Just follow the hose from the seacock. I found that if I turn my switch on and tap on the pump housing with a screwdriver handle it will start to run so I figure its got some sort of internal problem, I am not sure if these can be taken apart or not. Maybe just time for a new one? It looks like it may be tough to get at the mounting bolts.
Joe.
Re: GW Livewell pump
Are you sure your not thinking of the "fresh water" pump? That's where mine was, (91 Gulfstream).
My livewell / washdown pump was originally under the rear, center deck lid. I replaced and moved it to the transom, (port side).
LiveWell
No; my livewell/washdown pump (Johnson) is under the port seat pedestal as I mentioned. The freshwater pump for cabin sink is mounted in the f/w tank and is below the livewell pump . I do not have gunnel-mounted f/w on my Gulfstream.
