Livewell gained from a 4-stroke conversion?
Greg B
Jupiter FL / Manteo NC
Looks like I've got the deal for my Suzuki 300 worked out for the Islander. I'm thinking of putting an inspection hatch in the port cockpit area to access the trim tabs and relocating the fuel filter. Then I could convert the plastic insert into a livewell.
Any thoughts?
Greg
Any thoughts?
Greg
Greg - I suspect many folks don't understand the plan well enough to comment. Not sure which plastic insert you're referring to and how that relates to an access hatch to trim tabs?
Rob
Rob
Thanks. There is a plastic insert under the hatch on the portside transom - looks like a plastic bucket. Lifting it out gives access to the oil tank, trim tabs and fuel switch/filter. As the oil tank will be gone and I think the other items could be relocated or access via an access panel from the cockpit, I think I could convert the pail into a transom livewell as opposed to the one under the port jump seat.
Probably best if I take some photos.
Greg
I have two of these on my 265 that are similar to what you describe, they hold maybe 1.5 gal each, I use them for small baitfish as is. I did add gasketing around the lower edge to keep water from getting below, it will splash out of the bucket as you ride, but if it is gasketed it will just flow overboard instead of down. I'd also keep anything below it well oiled to prevent corrosion. I use it without a pump, and it keeps my small baitfish(1-1.5") alive all day, I usually refill the water one or two times during the trip. Be aware, even with the gaskets you may get some water below so keeping everything well oiled and cleaned is important. We did not gasket it right away and our fuel/water separator mounts went to hell and we had to replace the whole kit. I coat anything below it that is metal in vasaline, that keeps saltwater from harming it and also prevents corrosion from normal use. Hope this helps a little.
