- Jan 23, 2022
- Age
- 75
- Freedom 335
I assume the Livewell on my boat has never been used. Tried it out and pump ran when seacock open but no water showing up.
Put boat in wash rack and set up hose to clamshell under boat and opened seacock, ran pump, NO water. Opened plastic "NUT" on pump lower side tried again with water and seacock open and no water Showing up.
Seacock turns with handle and rotates shaft. So question is whether the ball would be stuck but shaft still turns and what function does small "screw" on side of valve serve. Didn't take pictures but all my valves are similar so assume it is a standard GW uses.
Did not peek into clamshell but all other ones look the same and no growth on them on surface anyway. Boat has been first lift kept and now in dry stack rack.
If there were to be growth etc in clamshell could it really clog it entirely so no water would seep through?
Boat show day tomorrow in FL Ft Lauderdale so will also ask around. Together with my Radar problem Raymarine, only showing targets up to 2NM.
H
H
