Loaded Weight for Grady Freedom 275
rifraf4u
Does anyone have a good estimated on the loaded weight of a Freedom 275 - fuel, motors (200's), fresh water, reasonable equipment et al - for trailer sizing purposes. thanks.
You can get the dry weight and specs for you boat on GW's site. Motor weights can be found easily enough, too. 2 or 4 stroke? But you could figure roughly 500lbs each. Add for batteries at about 50lbs. Gas is about 6lbs and water is about 8 - but you can look up the exact weights if you want. Add for any optional equipment you have and then estimate for your gear. Add that all up and you should have a pretty good idea. Add another 10% for good measure - especially if you're going with a "price point" trailer.
^^^ This. I'd use #600 for 4-strokes and #500 for 2-stokes but you can get off Yamaha's website. GW will provide the hull weight which should include the batteries. I figure #250 for gear. #8 for head.
