Fishtales Well-Known Member Joined Jan 31, 2005 Messages 8,517 Reaction score 1,404 Points 113 Jun 6, 2019 #1 Hi, Can someone tell me where this is located?
ElMar Well-Known Member Joined Sep 17, 2018 Messages 109 Reaction score 10 Points 18 Location Westbrook CT Jun 6, 2019 #2 If it’s like my Islander you need to remove the fridge. May be able to see it under the stairs to Port. Last edited: Jun 10, 2019
M Meanwhile Well-Known Member Joined Feb 16, 2014 Messages 566 Reaction score 104 Points 43 Location Warren, OR Jun 7, 2019 #3 My 2007 pump is located behind the tackle storage, under the bait sink.
M MA208 Well-Known Member Joined Mar 13, 2011 Messages 210 Reaction score 28 Points 28 Jun 7, 2019 #4 2005 same as No Bail. I had mine replaced last year as it died on me.
H hinmo Well-Known Member Joined Sep 2, 2006 Messages 150 Reaction score 15 Points 18 Jun 7, 2019 #5 access thru the mid bunk, port side, near the heater on mine
Ozz043 Well-Known Member Joined Aug 13, 2014 Messages 188 Reaction score 12 Points 18 Jun 8, 2019 #6 Yes mine is also on the port side as Hinmo states...
A Absolutely Nothing Active Member Joined Jun 20, 2017 Messages 28 Reaction score 5 Points 8 Jun 20, 2019 #7 In my 2004 the pump is behind the tackle storage boxes. Same as No Bail.
M Meanwhile Well-Known Member Joined Feb 16, 2014 Messages 566 Reaction score 104 Points 43 Location Warren, OR Jun 21, 2019 #8 I can post a photo if that helps. I just changed out the fresh water strainer bowl as it was not only plugged but also cracked from a bit of ice. Last edited: Jun 21, 2019
