Moeller live well help
rick0520
Hi, if a boat has no live well could I buy a Moeller, cut a small hole in the side and run a hose from the raw water spigot into the Moeller? Then cut another hole in the other side and connect a hose allowing water to escape? I would only need this for Massachusetts saltwater baitfish. If the water keeps circulating through the Moeller thanks to the raw water pump will this work?
Thank you
