Need help -wiper motor wires (Sailfish)
grady33
Ocean Pines, MD
I'm replacing the port side wiper and was rewiring everything and can't seem to figure things out.
There are 4 wires going to the starboard wiper motor area - 3 of which seem live and the other is black so assume groung.
Orange/Green Stripe
Orange (plain)
Orange/Bloack Stripe
Black
Assume the black is ground but where the heck do the other wires go? The wiper motor Startboard side has 4 wires (#1, #2, #3 & BLACK) and the port side has 3 wires (#1, #3 & BLACK).
Any ideas how to run the wires?
Maybe it is the heat but I'm just not getting this.
Thanks,
David
Ok I figured the wiring out (I hope) and it seems to work including self parking. Here's the wiring in case someone else needs help with this.
Starboard: black plus orange and black goes to Port side ground wire.
Starboard: orange wire goes to #1 wire and then to #1 wire port side
Starboard: green plus orange goes to #3 wire port side wiper.
Now the problem, i had everything working great except the port side wiper was set to 110 degrees so I changed it to 80 and now it wont park correctly. Thinking I may need to adjust the wheel inside. Anyone run into this before?
Jeez, can they make these wipers any harder?
