New Helm seats for 208
SC Adventure 208
My helm seats work fine and the cushions look good on my '95 208. Would like to find a more comfortable seat that I don't feel like I'm always falling out of. Anyone change their helm seats to something more comfortable. Concerned about clearance between the seats.
Having a seat that you don't fall out of usually means a set with arm rests. Those can be fixed or movable but in just about every case, the already narrow clearance between seats will be reduced. You could change just one set to minimize the space impact but your better half might not be fond of that idea.
On my 208, I stand and lean more than I sit but I I also wanted a higher seat when I do sit since my center of vision was blocked by the top frame of the windscreen. I looked and looked for an adjustable base but couldn't find one with a D base and also didn't need clearance below the base.. I used to put an extra cushion on top of the original cushion but that was not ideal for several reasons. I toyed with the idea of having a thicker cushion made that would snap in like the original just taller.
I ended up getting a fixed extension (6 inch rise) that I cut to the the size I needed
I'm 6'4" so don't need the extra height. Not sure I like the idea of two different seats but if I got a new one it would go on the port side for sure.
I am a bit confused; Who drives the boat?
If it is you and don't want to feel like you are falling out of the seat, why would you replace the port seat?:)
