New Owner of 2004 Grady Express
Offshore25
I’ve been getting a pretty good education reading all the threads. Just got the boat home a few days ago I can’t figure out how get the helm electronic hatch to lift. I have the electronics switch on in the cabin and main switch on at helm. All other switches work at helm.
Seems to be a common problem with the ram that lifts the electronics hatch. It is located behind the cabin electrical panel almost amidship. Make sure the circuit breaker or fuse associated with that switch is not popped. Otherwise access the ram from underneath and check the wiring and replace it if necessary. You may be able to free the ram manually, easy to overdrive the ram to its limits in either direction and make it jam.
