Hello, my first post and first boat. I took a risk and bought a GW seafarer 1986 227. It has a 4.3l gen + thunder V ignition. It is carbed. Then engine lower was rebuilt and has 15 hours on it and has been sitting since 2003. The boat is structurally very sound....stringers and transom are rock solid...at least the stringers that I can see. I took a risk because it wasn't running...I know I know...but I got it for cheap. I can probably sell the trailer off and make back 60% of what I paid.
I changed the fuel pump and filter today and im running the fuel line from a small 6 gallon tank to eliminate fuel take issues. I am getting fuel up to the carb. not sure if it is making into the carb. Im by my self at the moment. It turns over with a squirt of starter fluid. I suspect the carb is gummed up a bit. Any suggestions? Im going to get some carb cleaner and try that. Thanks in advance and excited to be apart of the forum here and a GW owner. Engine serial number is 0m008448 if that helps.
