- Sep 1, 2013
- Allentown, PA & Friendship, ME
- Offshore
Ah, OK - yes the access lids are the "inspection lids"... or pie plates. You're good - if you had eyes in there and no more water was running into the aft bilge from the forward area of the bilge, then you're good.
Yes, very normal for boats with floors that are close to the waterline to have water come into the boat when there's extra weight on one side of the boat while at rest. Nothing to be alarmed about - it will all go right back out again.
New flappers may help alleviate that... but it can still happen with new flappers - they are more designed to help keep water out when backing down.
You don't have to move any batteries - just put someone that weighs between 100 and 140 pounds at the exact spot on the other side.
