No power.
thepenman
Miami
2008 express. Arrived at boat. shore power breaker was tripped. Reset. Worked for several minutes. Got enough batteries to get the generator on. Now charging batteries. 30amp power inlet had positive and negative fried. Replaced it. New shore power line with dummy lights. All good. NOTHING in the boat. Tripped and reset every main breaker I know of. Any suggestions?
Reactions: sneakattack
Check the wiring diagram in your owners manual. The switch is located just underneath the gunnel starboard side all the way out towards the tuna door inside the rod holder area. It is up and under the gunnel.
That woulda cost you $300 at the marina and a two week wait!
At least double if not triple that. And who knows if I would have been told I have so many other parts to replace first. As a wanna be DIY I try first. I do the same with two other toys I have. Now soon to add a rolling boat. I’m a glutton for punishment.
