G gradywhite248 Well-Known Member Joined May 6, 2014 Messages 185 Reaction score 0 Points 16 Mar 1, 2025 #1 What size trim washers do I need for the little screws around the breaker panels/switch panel on a GRADY-WHITE 248 they’re nylon I believe Attachments IMG_9198.jpeg 1.4 MB · Views: 17
S seasick GreatGrady Captain Joined Aug 19, 2008 Messages 9,756 Reaction score 1,479 Points 113 Location NYC Mar 1, 2025 #2 Are you referring to the Trim caps that cover the screw heads? If so, look at PRO-DEC.com for the biggest selection Last edited: Mar 1, 2025
G gradywhite248 Well-Known Member Joined May 6, 2014 Messages 185 Reaction score 0 Points 16 Mar 2, 2025 #3 seasick said: Are you referring to the Trim caps that cover the screw heads? If so, look at PRO-DEC.com for the biggest selection Click to expand... That is correct thank you I’ll give it a try
Ky Grady GreatGrady Captain Staff member Joined Mar 1, 2006 Messages 3,069 Reaction score 1,378 Points 113 Location Berea, KY/Cross, SC Model Seafarer Mar 3, 2025 #4 Exactly what I used, Pro-Dec. As close to a dead on color match as I've seen. Antique White. Reactions: family affair
Fishtales Well-Known Member Joined Jan 31, 2005 Messages 8,232 Reaction score 1,344 Points 113 Mar 5, 2025 #5 I went with tan caps. There is a clear plastic washer that goes under the screw head and the colored cover just snaps on.
5-Salt Well-Known Member Joined Sep 11, 2005 Messages 282 Reaction score 16 Points 18 Location Oregon Model Voyager Mar 28, 2025 #6 2nd that. Hinge Snap-Caps from Pro-Dec in color of your choice Reactions: Ky Grady
Ky Grady GreatGrady Captain Staff member Joined Mar 1, 2006 Messages 3,069 Reaction score 1,378 Points 113 Location Berea, KY/Cross, SC Model Seafarer Mar 28, 2025 #7 5-Salt said: 2nd that. Hinge Snap-Caps from Pro-Dec in color of your choice Click to expand... Exactly what I used. Hinge snap-caps.
JJF GreatGrady Captain Joined Feb 14, 2021 Messages 547 Reaction score 167 Points 43 Location Gloucester, MA Model Canyon 306 Mar 28, 2025 #8 It's amazing how such a little detail can make something look so much better (and cleaner).
