- Sep 30, 2012
- Massachusetts
- Express 305
I was looking to replace the 4 drains on the rear of my 1986 Offshore open rear transom. My transom appears to be in solid condition, I had a surveyor inspect it prior to purchase 2 years ago and he said there was nothing to worry about and it look great. I just unscrewed the rear scuppers and noticed there appears to be a brass tube through the hull that these scuppers screwed to. Is there a kit to replace the tubes since the ends looked to be cracked where water can get in or do I need to just fill it all in with below the waterline caulking and replace just the gasket on the skuppers?
Looking again at the photos it looks like the brass plugs are knocked in from one side and they were alternated. I just want to make sure I am covering all of my bases to prevent water for getting in. I already resealed the aluminum angle iron cap when I had the motor off last year.
Attached below are some photos
Andrew
Andrew
