Hi All, I am new to the forum. Could somebody please help diagnose a problem with a 1999 Yamaha 130 BETO two-stroke-cycle outboard engine 205 hours on the clock. After fitting fuel pump kit, plugs, new oil filters, new thermostats, new primer bulb and new fuel filter and fresh oil, it runs like a dream. I can troll without any problems or I can go to full throttle and it goes like a demon. But, if I go to full throttle, after 4 seconds, the oil warning buzzer sounds, the motor goes into limp mode and the three indicators on the dash gauge flash, signifying that the engine oil tank is low.
I stopped immediately and checked the oil level in both engine oil tank and the motor mounted tank only to find it was full to the maximum mark on the tank. The remote tank had about 8 litres of oil in it. The motor heat felt normal and there was no overheat indication. I went back to the jetty, removed the engine oil tank, cleaned it out, (no dirt in the filter), refitted the oil tank and checked the oil pump operation. It fills the engine tank to the mark and switches off. If I remove the sensor unit from the tank, it works correctly and sounds the buzzer at the low point. It idles fine and gets out of the hole in about 2 secs, but if I go to full throttle, after about 4 seconds, the oil indicators flash and it goes into to limp mode.
The strange thing is that this only occurs if I exceed 4100 rpm. If if run it under 4000 rpm it will go fine all day but the problem remains! Could this be something in the electrics? According to the manual, all three oil bars will flash indicating that the remote tank has oil but the main (engine) tank is low on oil. I have driven with the cowling off and monitored oil level. It maintains the oil level in the engine tank at the maximum mark on the tank. The motor runs at a normal temp and the thermostats are new. Water pressure release valve opens at 18psi at high revs. The battery is fully charged. Charging output at 1500 rpm is 14.8 volts DC.
Sorry to be so long winded but I'm stumped! Any advice would be much appreciated. :?
