- Jul 4, 2021
- Age
- 72
- Adventure
My 2004 208 has 2014 Yamaha 150 main and 9.9 high thrust long shaft kicker (electric tilt).
With the Garelick EEz-In motor mount completely up and kicker in its full up-tilt position the kicker prop drags in water, even with trim tabs applied. This is the set up on boat when I purchased it.
I’ve found a thread or two from several years ago on the sight where the Panther Marine Model 35 has been used to get around this problem. It sounds like this could be the solution but I’m curious if someone who has experienced this issue has suggestions for the most current solution/s available?
