My buddies has a soft tank bladder, not sure of the brand but I can find out. He straps it in his cockpit and then stores it after he burns it on the way out. His is roughly 80gal. He actually put in a T in his fuel lines and added quick disconnects from the fuel bladder to the T so when he uses it is connects quick and fuel is pumped from the tank from the lines suction and the pump, and when used up he just changed the valve direction, disconnects it and folds it up. They are very durable and will last a while if cared for. I would NOT sleep or sit or lay on one, it is fuel after all and I'd stay away from it when possible, plus they are not designed for that type of punishment. If your pushing your fuel limit, they are a great addition and are very reliable and fairly easy to use if set up correctly.
